ADAHRS failure and internal error big X screen
Jung kyu-chul
hi!
I wanna your help
my unit is sv-d700 several days ago I did upgrade my unit to version 15..4.7.5568(latest version)
and about two weeks I didnt fly because my place got the seasonal rain.
then I have booting but appeared big X( internal error: multiple sensor error) on screen
1.2.5 button push and rebooting then other problem like below picture.
airspeed and gyroscope is incorrect.
always first booting screen appear big x screen(internal error)
after rebooting that not properly wok( airspeed, wind direction, gyroscope)
often when flight happen alert( check pitot heat)
my analog instrument(airspeed) is good work correctly.
sv-d700 's altitude work correctly.
please tell me know why happen and how repair.....
may be I think that cause concerned with upgrade....
3551
3552
3553
Jung kyu-chul
today's second booting screen
first booting appeared internal error(red X screen)
so rebooting then second screen is below it.
my plane is stop. analog instrument is correct but adahrs is error(bad airspeed indicate)
3554
There is a lot going on here so there are 2 things I would do --
1 - Make sure you are seeing all the Dynon units on the System Status screen - if not, then do a system configuration. that may fix it &
2 - Perform the Zero airspeed calibration as described in the install manual.
If you're seeing 100 knots on the ground, there may be something up with your ADARHS. BUT, if the airplane was out in some rain, I'd also explore whether there might be some water in the pitot or static lines upstream of where the lines are T'd off between your ADAHRS and analog IAS indicator.
Jung kyu-chul
may be I think that reason is firmware. so I want to downgrade to my unit.
or reset my adahrs module.
how can I downgrade or reset my adahrs or sv-d700?
Software versions have no bearing on ADAHRS performance, and there isn't a way to "reset" the ADAHRS outside of doing the zero airspeed calibration.
Bohn Jon Bovi
EDPS
Hi,
I have the same issue with Sky View. It appears regularely when the System was shut down at technical Landing. Never when booting the first time this day. Can it be connected with heat? Maybe without air circulation on the Ground it gets overheated?
When I reboot for, lets say 3-8 times, the error is gone and it keeps running perfectly until the next stop.
Hard to say - there isn't a known issue that causes ADAHRS issues in heat. I suggest you get in touch with our support team at 425-402-0433 or support at dynonavionics dot com.
