jaba-who
I have finally got around to addressing a problem with my ammeter present from when I initially installed my D-180 2 years ago.
Basically the ammeter is little more than a random number generator. The pattern is for it to start about - or + 1 or 2 then to fluctuate up and down in sort of sinusoidal pattern sometimes dipping down to -6 or -7 though not often peaking up over +3 or 4.
It does this no matter what the connections are. I have tried it with the sensor wires disconnected from the shunt, shorted to each other, with and without the main 12v wires connected to the shunt and even with all the rear looms/connectors (and thus all wires) removed from the dynon itself.
With the sensor wires shorted to each other the spread was all - amps but still in a sort of waveform.
It doesn't really seem to be altered by real loads too much - perhaps at most a tendency to run in the - range.
Any hints?
Any hints?
