The directions state:
Pin 24 O/G AMPS high?
Pin 25 O/P AMPS low?
Is this the hook-up on each side of the shunt, if so what side is the high side?
I have an Ellison throttle body with no taps for the carb. sensor. Where should I drill & tap one in? Should the probe be in the air flow? Is there a drawing on this?
My EFIS-D10 is on the way back to you for an altitude glitch. Will it come back with the latest software?
Garys
Garys
