On the AP panel can someone confirm or deny that the ground on Pin 2 (for use with trim motors) and the ground through the network are internally connected? I was trying to interrupt pin 2 ground with a switch to kill motors. The motors however still work even after disconnecting the pin 2 ground from the switch. Unless my wiring is wrong which I don't think so, the only other place I can see the motors getting ground is through the network.
Thanks for your help.
