Biennial Pitot/Static check procedure
GalinHdz
KSGJ/TJBQ
I read there is a new Pitot/Static check procedure for SkyView that eliminates the need to power SkyView on and off as before. Where is the procedure located? I can't find it in the SkyView Install manual.
I love aviation!
I found this via search.
Available via SETUP MENU > HARDWARE CALIBRATION > ADAHRS CALIBRATION > PITOT / STATIC TEST MODE"
The manual needs updating, but if you use the feature in the above menu, you need not power cycle SkyView on and off between pitot/static pressure changes.
