Hello Mr. Dynon, thank you for your explanations.
I think you are prisoner of a strange paradigm: that a BRG needle must be related to the aircraft's route.
Strange, because in classical instrument panels this is not the case: you can set a "needle" to whatever off-route navaids you want.
Even more strange is the concept that the HSI and both BRG are tied together to the same waypoint - unless you install additional hardware, for which there is no logical reason (and no money): Skyview has all the information needed.
Note that the HSI doesn't really care *what* it is tuned to. You don't select the airport, waypoint, or VOR with the HSI. ... it displays exactly what the connected navigation device tells it to.
So design-wise (or paradigm-wise) things are upside-down:
The GPS shouldn't tell the instruments what to display, it should tell them the position and let the instruments decide what to display based on this position, their settings and the Skyview database.
Somehow we would need a user interface to allow you to select more than one flight plan in SkyView
You
have that interface, it's identical to direct-to and permits the same selections. Except that it would not change the FP or current waypoint, only set a BRG needle. Nobody wants more than one (current) flight plan.
I know it's blasphemy, but I even want to have HSI/BRG1/BRG2 indications without any flight plan or direct-to.
In this case, I don't quite understand the way it would be used.
I would be embarrassed to lecture the high-grade pilots in this forum how bearings to off-route navaids can be used. Watching the map and pressing every once in a while the direct-to, scanning through the list, finding the bearing, is not an alternative.
So let me resume this thread:
a) what I want is technically easy, but
b) the Skyview paradigm doesn't allow for it and
c) I try to resolve problems nobody else has
