I have a new CTLSi, w/ 100% Dynon gear inside. 3 screens. The middle startup screen is set to reveal the EMS. My CFI started the plane last week, the following condition occurred, his words:
While going through the engine start sequence - I turned on the battery switch which then turns on the center Dynon display. As usual all instruments have an "x" through them as they are not reading anything. Then I went through the engine start checklist and started up the engine. The engine started fine, but the display did not update with the engine information such as RPM, Oil Pressure, Oil Temp...etc.. there are numerous gauges on the display and none of them were reading anything. They all had the x through them.
When the engine started I switched on the avionics switch the other two Dynon displays on the pilot side and co-pilot side started up just fine. They displayed their usual information. I used the one in front of me to then try and read the instruments, and it too was not reading anything.
I let the engine run for 2 or 3 minutes to see if the gauges would read but nothing changed. So then I went through the shut down sequence and turned off the engine and all avionics. I also turned off the battery and generator.
Then I went through the whole process again and re-started the engine. This time the engine monitoring display showed all the instruments properly and everything was fine. The run-up period and follow up flying to other airports occurred without a glitch.
So Dynon, it was a 28 F degrees morning, the temps were lower that night. Do you believe it was a one-off cold weather issue? Should I send this middle screen in for repair?
Please respond and thank you in advance for your follow up.
Andrew
Andrew
