I have the D100/120 (and AP74) installed in a SportCruiser. Both units have the bright screen option but for some reason the D120 unit is very much dimmer than the D100.
The units boot up at about the same brightness but as the brightness on the D100 changes with Auto Dim or is changed manually the D120 screen frequently becomes too dark to see in flight.
Have performed alignment, DSAB and power cycle as suggested elsewhere in the forum but the problem remains.
Would greatly appreciate advice on how we can diagnose/fix this problem. Happy to supply serial numbers etc. if required and also have system backups again if required for investigation.
