D100 and SL30
Letpmar
Forgot to ask will I get VOR and glideslope with my SL30 connected to my D100 or do I need the HS34
Thomas_Schaad
With the SL30 you will get both of them. You will need to select the OBS on the SL30 which doesn't cause any problem in daily use and you will be able to display two RMI needles at once on the EFIS, the one in the active NAV frequency on the SL30 and the one on STBY as well.
If you switch your EFIS from NAV to GPS (changing NAV source) your only RMI needle will be the GPS one. You won't be able to mix GPS and NAV.
Kind regards
Thomas ;)
Letpmar
Thanks so the CDI on the dynon will display the VOR and glideslope without an HS34
Some people seem to be telling me this only works with a HS34
Pete
Yes, with the SL30, you can just wire the serial to the EFIS and get the VOR, LOC, and GS.
You need the HS34 if you have a 430, or if you want to set the SL30 course on the EFIS instead of on the SL30.
