D10a and Becker BXP6401 set up
deborahj
Hi Guys, What is the set up for a D10a and Becker BXP6401 transponder to enable altitude encoding? I've tried just about all the variations on both boxes. The transponder check failed. I get a Becker Error Latch of DATA LINK and of course FAILURE showing up sooner or later. Thanks, John in MN
The link below is for the Becker transponder if anyone would like to take a stab at it. Much appreciated. THX, John
file:///C:/Users/System%20User/Downloads/BXP6401_I&O_issue05%20June%202018.pdf
It turns out that two wires on the Becker harness I purchased were in each others pin. The other problem was that there was a ground on one of the db connectors that, due to my panel setup, should not have been there. The BeckerUSA tech guy was a big help in helping figure this out by offering suggestions and pointing me in the correct direction.
Back
