D700-Screen failure in flight
pe190
I have 2 D700's. One was replaced just over a years ago due to this problem. Now it looks like the other one is playing up as well. The screen will fail and go stripped mulit-color see attached pic. A 1,2,5 reboot will fix it but then it sometimes fails again soon after.? I have the latest firmware updates and I am running pocket FMS.Also 1 ADAHRS and 2 AP servos
What can be done? :-[
Two identical failures like that, and the description you give makes me wonder about overheating. Can you go into setup, local display info, hardware status, and give you CPU and SYSTEM TEMP after the unit has been on for a while? You'll need 3.3 firmware to do this.
pe190
After flying for about 35 mins the screen failed again as above so i 1,2,5 rebooted and check internal temps both cpu and int temps were 53 deg but the fans were at 0 rpm.The faults seems intermittent as it does not always happen on every flight.?
At what temps do the fans come on?
That doesn't sound temperature related given that extra data. Give our support team a call at 425-402-0433, and make sure to mention this thread and that this is the second display that has acted up on you.
