EFIS-D10A Install Guide Typo?
Dave H.
Is it just me or are the "A"s and "B"s mixed up here?
EFIS-D10A Installation Guide revision J from August 2010 page 6-5:
AP74 ELECTRICAL INSTALLATION
When installing the AP74, we recommend building enough slack wiring into the D25 connector to allow the AP74 to be removed from its tray with the connector attached.
Use the D-sub pins/connector kit included with your AP74 to make the following connections:
Pin 3: Dynon Smart Avionics Bus (DSAB) “A”, connected in parallel with all other DSAB B connections (Blue wire on Dynon-supplied wiring harnesses)
Pin 4: Power, 10 - 30 volts DC
Pin 16: Dynon Smart Avionics Bus (DSAB) “B”, connected in parallel with all other DSAB A connections (Green wire on Dynon-supplied wiring harnesses)
Dave
Hmmph, how about that. I'd thought we'd totally debugged that manual by now. You're right: All "A"s go together, as to all "B"s.
