I have a D10 installed in my now-flying RV9A (maiden flight April 23). Works great! Remote compass and oat is working flawlessly. Of course, I am extremely jealous of the newer larger displays that are currently shipping...... oh well....
A few operational questions that I don't see in the literature.
When I set the barometric pressure, I see varying amounts of error in the indicated altitude when compared to the field elevation. None have been large - 40 feet to 60 feet at times. If I use the alt-adj function, the next time I check (a few days later), I find that I need to adjust the altitude again to get back to field elevation.
I also see some discrepancy between the indicated altitude when in flight, and the altitude readout from my King KT-76C transponder (Dynon encoder used to drive the transponder). Sometimes it is right on and other times as much as 200 feet off - suggestions for solving this?
Finally - I am working on a small project that requires the use of a small screen that has all the characteristics of the one used in the D10/D10A - daylight visible, wide viewing angle, 4" size or thereabouts. Can I get some information on the source of the screens used in the D10/10A?
Thanks -
Brian Southard
N355RV
RV9A - 30 hours in flight!
Thanks -
Brian Southard
N355RV
