I am installing an EMS 220 with a Rotax 914. I've read the installation manual until my brain has turned to mush, so I'm probably missing something obvious. If I understand correctly, any one of the black/ground wires from the 37 pin connector needs to be connected to the engine mount where other grounds are. And I'm not clear if I need a ground wire from the EMS 220 box to the engine mount/common ground. If so, what size ground wire is needed.
David Daniel
David Daniel
