EMS-D10 and 4 EGT sensors on Rotax 912
tpatja
EFHF
Hi,
The standard sensor package for Rotax 912 contains only two EGT sensors. I would like to have EGT sensors for all four cylinders. The installation manual does not make it clear how to install more than two EGTs for the Rotax. Is this possible with the Dynon clamp sensors and if so, how?
Thanks.
Simply buy two more sensors, and either add more EGT wire to your existing D25 connector, or buy a new 4 cylinder EGT/CHT harness and not use two of the CHTS. Then reconfigure your EMS under global settings, and that's about it!
