flipfloplife
- Joined
- Apr 8, 2021
- Messages
- 3
EMS-d10 install.
Aera660 to drive fuel flow functionality.
but i would really like to constant serial capture for engine data (have serial logger solution).
i THINK the wiring diagram shows 1xTX and 2xRX within the larger wiring harness. (so i already don't know what to do with the ground since my aera660 only has 2 wires, a tx and an rx...)
Soooo... could a fella just roll his own DB9 and use one of the RX for the aera660 GPS signal in and then use a tx/rx pair for the logging?
If so ... uhhh... what does that look like? I see one tx and two rx wires on the harness - and one ground. Supposed to go to pins 2,3 and 5 of a DB9 -- i'm thinking maybe put the secondary rx at some spot in the DB9 and then perhaps i could hook both the aera660 info IN at the same time as the EMS data out?
i'm just using keywords -- i barely understand what I'm talking about here...
Thanks,
scott
Thanks,
scott
