I have a gyrocopter with a Rotax 914 engine. I get the engine tach off the TCU pin 13 and feed it to pin C37_34 on the EMS module, and all is happy. In addition, I also need rotor rpm displayed on the EMS page.
I connected the pulses generated by the rotor tach sensor to pin C37_35. In the .DFG file I added this:
c37_p33/35_v2={
valid=1
name=ROTOR
id=RPM
alarm_type=SELF-CLEAR
range={...}
Then I loaded the modified .DFG file via USB stick and went to the EMS screen editor, expecting to be able to place a new widget called ROTOR there. In fact, I found the new Rotor RPM widget but now the Engine RPM widget is gone.
On the Sensor Input Mapping page I see both RPM sensors on pins 32/34 and 33/35, respectively.
There must be someting fairly obvious I am missing. Can someone point me in the right direction, please?
Thanks, -- Chris.
c37_p33/35_v2={
valid=1
name=ROTOR
id=RPM
range={...}
Thanks, -- Chris.
