Ron777
I am in the process of installing the D180 and have successfully integrated the SL30 Navcom to the Dynon.
I am having problems getting the Garmin 150 Xl to talk to the Dynon. I am in the early stages of troubleshooting & will check all pin connections and output strings in the coming week. Configuration as follows:
Dynon D180 & Sl 30 OK via serial input to Pin 22 on DB25- OK
Dynon & Garmin 150xl .(Pin 19 on Dynon DB 37), and (Pin 19 via I/out 2 on GPS)- NO COMMS
Shadin Miniflow to Garmin 150 via I/Out 1 on GPS -OK
The garmin outputs on I/O 2 are:Serial position,velocity,navigation & satellite data to NMEA 0183 V2.0 compatible mapping devices or Garmin PC Software.
Before I get entangled in the wire jungle, can anyone shed light on the suitablity of the Gps 150xl output data via I/O 2, and whether the Dynon is sensitive to Baud rate.
Any help or suggestion would be appreciated.
