Hello All,
I request a simplified method of entering a flight plan.
I would like to select any way point, airfield, navigaton aid. It highlights and on the bottom of the screen should be a simple "Add to FPL", same functionality should be to "send frequency to COM" if it's an airfield.
The way it works now is that I touch a waypoint, it highlights and then I have to press the "info" button first.
The screen splits in the info part and map part and the "add wypt to FPL" pops up. Then you need to close the info box and select the next desired way point on the map, press "info" again and so on. If I don't close the info box and highlight a another way point the info box doesn't update even after hitting "info" again. An auto update for the info box would be a nice feature too. So as soon as you select a different way point on the map the info box updates itself to the new way point. Currently you have to close it. Too many presses.
Please contact me with any questions.
Andi K
Andi K
