I am installing a UL350is (red ECU) with a Skyview HDX and Dynon EMS-220. I am using the Lycoming 4cyl fuel injected sensor kit. Can you confirm the configuration for tying in the RPM and injector pulse (fuel flow) parameters from the ECU harness to the HDX main harness? There are 2 wires on the UL power ECU harness for “Injector pulse” and “pulse/litre” and one wire for RPM.
