Hello, I will soon be installing my Dynon system (D800) and wanted to configure my existing fuel pressure sensor. The sensor manufacturer gave me the sensor characteristic curve. I read the instructions carefully and wanted to ask if I had entered everything correctly.
I have a question about the pull up or pull down resistance. At the moment I don't need one for my current EFIS. Do I have to switch something here?
Thanks in advance for help.
Sensor characteristic curve:
And here the config file:
sensor={
id=MEMOTEC
function=PRESSURE
pins=C37_P8 C37_P22 C37_P23 C37_P31
name=FUEL PRESSURE SENSOR
min_val=-1
max_val=5
resolution=0.1
round=0.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0.0012
c_x0=-1
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=
c_x3=
c_x2=
c_x1=
c_x0=
high_resistance=NONE
high2low_cross=0
window=0.1
shift=3
age=
sensor={
id=MEMOTEC
function=PRESSURE
min_val=-1
max_val=5
resolution=0.1
round=0.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0.0012
c_x0=-1
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=
c_x3=
c_x2=
c_x1=
c_x0=
high2low_cross=0
window=0.1
shift=3
age=
