GRT Current Sensor
MCRider
Germany
Hi,
I am planning to add a current sensor to my factory-installed SkyView and have decided that the GRT CS-01 is easier to install than the shunt. I do not need the 100A range, 50A would be perfectly okay. In theory it should be possible to run the wire through the sensor two times, modify the sensor setup file, get half the measurement range and twice the accuracy. True or not?
Thanks for any help.
MCRider
Hi,
MCRider
In theory, Yes :cool: We're working on documenting the process for defining your own sensor to make it doable by mere mortals, but probably not done by the US Thanksgiving holiday.
MCRider
Germany
Thanks.
Now I have found the documentation for the sensor. It even suggests to loop the wire to let it pass two times through the sensor in order to get a -50 to +50 A range (or 10 times for -10 to +10A).
Since the polynomial for this sensor is really simple (just a linear component and an offset) I will give it a try...
MCRider
Germany
It took a very long time before I could mount the GRT CS-01 with two loops and a modified sensor definition. Now it is done and it works (I still have to verify the measured current with an ammeter but the readings seem to make sense).
Just in case this information is useful for anyone...
MCRider
Germany
Just one little problem left: The measurement does not appear in the user log data. The "Amps" column seems to be hardwired to the shunt sensor definition instead of looking at the "function=AMPS" assignment in the sensor definition file.
Or am I making a mistake?
MCRider
Germany
I think I might have found it by myself:
Sensor definition:
sensor={
id=AMMETER HALL EFF +1.5 (GRT CS-01 TWO LOOPS)
function=AMPS
pins=C37_P8 C37_P22 C37_P23 C37_P31
name=AMPS
dfg file:
c37_p31={
valid=1
name=BATT
alarm_type=OFF
Probably the sensor name is too long. In the dfg file it is truncated. I will try a shorter name.
If it does not work I will send the sfg, dfg and a log file...
MCRider
Germany
Did a test flight today with the changes - still no amps in the log file.  :(
What is the best way to send you the files (less than 600k ZIPped)? PMs do not allow attachments.
First, the config files do only support a name length of 40 characters for the ID. Longer doesn't cause any issues, but it doesn't get used.
As for AMPS being in the datalog, we were a bit off here. It will not be in the AMPS column, that is only for the AMPS shunt. If you are using a hall effect, it will be in the GP X column, depending on which GP you have it wired to. It's in the datalog, but it might just be in a different place than you are looking. In your case, it would be "GP INPUT 13" which is column CU in the CSV, assuming you are connected to pin 31.
MCRider
Germany
Okay - but I still can't find it in the data. The sensor is connected to pin 31 but the "GP INPUT 13" column is empty. I have already mailed the data files to the support email address.
Just to put it in perspective: It is not a big deal - I just wanted to help to fix a little bug (it there is one at all)...
Thanks for the datalog. There is a bug there, it turns out. Things that the system knows about as a special function, like amps, are unfortunately not logged when they're hooked up to GP inputs. We've logged the bug for our engineering team to look into.
MCRider
Germany
This is not fixed yet (software 10.1). Is there a chance to get a fix in the next time? I'd like to use the amps in the log file to compare the behaviour of a lead acid and a LiFePO4 battery...
Sorry. In all honesty, with only one customer request for this it is not at the top of the list. It's not scheduled for the next release.
lgabriel
Make that two! Surely there are more of us with dual electrical systems...
MCRider
Germany
I'd like to bring that up again (Measurements of GRT CS-01 current sensor not showing up in log file). As "promised" it was not fixed in version 11...
MCRider
lgabriel
I haven't lost interest in this either--it would be incredibly helpful to analyze what my right electrical system is up to.
