I've been flying my RV-10 with the 6 cylinder EMS-D10 now for 14 months and 190 hours. In the last 15 hours my #2 cyl EGT was showing >1500 when it is normally in the low 1400 when I run lean of peak. I initially thought something was up with the cylider, so I cleaned plugs and injectors and no change. I then swapped the probes for #2 and #4 cylinder and test flew it and now the #4 cyl is >1500 while the #2 cyl is around 1400. So it is diffently an issue with the probe. This bad probe is also very unstable and bounces around and gives false peaks. How long are these probes expected to last? Do they need to be cleaned? If so how? If this is a bad probe, can Dynon send me a replacement probe?
Ray Doerr
Ray Doerr
