HS34 Woes.
N747PW
I have just fired up my recently installed new panel. It sports one D100, one D120, one D10A and an HS34. I wired the DSAB such that the D100 consumes one port on the D120 and the D10A and HS34 are bussed to the other port.
The problem is that the D100 can find nothing if there is power applied to the HS34 and the D10A can only see the D120. If I remove power from the HS34 all the remaining devices join and are happy after configuration.
I was bitterly disappointed to see this massively impressive panel that wouldn't work.
Please help.
Pat
aceflyingservice
I had a similar problem with a D10A EFIS, D10 EMS and an HS34 configuration. The EFIS and EMS were happy together, but plug in the HS34 and nobody would talk. The HS34 is the new kid in the panel, so suspicion fell on it. As it turned out, the HS34 was shipped with ver 1.0 firmware (per the DYNON support program.) After updating to the current ver 4.0, all is well.
Roger Johnson
LongEZ N34JR
