I recently flew some real IFR in my RV-8 behind a D-1000. I have about 300 hours using it so far mostly VFR. I wanted to ask if there are others who think the sensitivity of the Pitch, airspeed, ball and VVI are just a bit to rapid in their response to turbulence etc. Maybe it is just my installation so that is what I want to get a feel for.
In relatively smooth air the airspeed constantly hunts 1-3 kts and in turbulence slightly larger oscillations occur. The changes are very rapid. The same for Pitch indications. Although the RV pitch and yaw changes in turbulence can be significant, the actual change in aircraft position is little. However the Pitch response rate of the EFIS is instant as is the Ball which instantly slides from stop to stop with the slightest yaw. VVI has the same instant response. Although the altitude may remain within 20 feet during turbulence, the VVI can show 500FPM climb and decent almost instantly.
I have a Piper heated pitot tube in the standard Van's wing location and utilize the Static Port in the Pitot tube. The ADAHRS is mounted on a shelf behind in rear baggage wall.
My main reason for posting is to see if there is anyone else who would like to see the response of the Pitch, A/S, VVI etc dampened slightly to slow their response and make it easier to fly on the gauges. It was an awful lot of work bouncing around in the clouds and trying to stay on altitude.
I had a D1 as a backup and found it easier to fly using it as it did not respond quite as rapidly as the 1000. Maybe I'm just getting old and slowing down?
