My D-10A EFIS is serial number 003339.
I am just now getting to the avionics installation. I had powered it up to test it when I got it, then put it away. I thought perhaps the internal battery just needed charging, but after powering it up for a few hours from an external battery & charger source, the voltage display still says "primary=14v, secondary=0v, internal=0v", or words to that effect. The EFIS doesn't do anything if I try to power it up without an external power source.
I definitely ordered it with the internal battery, and there is a battery inside it, but it seems to be dead. Is there a way to resurrect this battery, or get it replaced? The EFIS has never been used or installed.
brian
http://brian76.mystarband.net/RV-7Ahome.htm
brian
