thebora
I seem to have hit a bit of a problem. The 'keep alive' line is wired through a switch panel, so that it is permanently connected to the aircraft battery buss.
I have just come back from a couple of days away and found the main aircraft battery completely flat and so was the internal backup battery on the D100.
I put the battery on charge, but although it is now fully charged, the D100 is indicating 0.00V for the internal battery. I have just removed the internal battery and checked it on a meter and it indicates zero volts, so it looks as though it has developed a fault which has caused it to discharge the main battery through the 'keep alive' circuit.
Any (helpful!) suggestions?
