Kavlico Fuel Pressure Sensor 101690
VH-IEW
I have 3 fuel tanks and need the 3 available "C" type inputs for the Princeton fuel senders. The recommended input for the Kavlico fuel pressure sensor is pin 8 which is a "C" type. I note however that the "sensor may be connected to any general purpose input pin" What are the issues here? Does use of the "A" type input compromise sensor performance?
No. The electrical principal of operation that the capacitance fuel senders need require special circuitry that are only on the C inputs. They won't work at all on non-C inputs. Other sensors that can use A or C will perform equally the same on either.
