Kavlico sensor question... KAV vs Dynon part numbers
Maccool
Replaced my EFIS (AFS 400o series -> 5400 series). My fuel pressure and oil pressure sensors (IO-320) are Kavlico 41,101 (0-50) and 41,301 (0-150) respectively.
Am I correct that those sensors translate to Kavlico Dynon part number 101716-000 for the fuel pressure sensor and 101693-000, which is apparently what I will expect to see in the configuration menu?
I love aviation!
Last year Dynon and others began offering a single sensor for both fuel and oil that is less prone to leaking, as some have. It is also more sensitive/accurate.
103757-000 (0-150)
Maccool
Yeh...I saw that, thanks. Something to be aware of for the future, but right now I'm not looking to replace those two sensors. I presume that these older ones will work OK, but want to make sure I get the sensor type entered correctly in the menu. The older EFIS used Kavlico part numbers in the drop-down menus, the EFIS I just installed in its place uses Dynon part numbers.
ETA:
I wasn't aware that AFS (don't know about Dynon) issued a service bulletin on this sensor issue. Advanced Flight Systems just sent me this, FYI. They used the F-word, which kind of puts a different spin on it.
https://www.advancedflightsystems.com/service-bulletin-050620a.php
RV8JD
WA State
Yes, Dynon issued an SB, as well as Garmin.
Dynon SB site below. With Dynon, you can sign up for notifications of SBs at the site listed below also.
AFS SB site:
Maccool
I did order a couple of those 103757-000 sensors. Do they use the same harness as the older sensors...101716-000 and 101693-000? Justt plumb them and plug them in?
