Left Info Field lost on D10A
Thomas_Schaad
I upgraded all my Dynon's to firmware 4.0. I used to have on the L/H Info Field OAT/DA/TAS and on the R/H one the digital VSI readout. Now having the new firmware in, I can't select anything anymore in the left info field. What is strange, if I switch the EMS10 to display the EFIS, then I get the information in the left infofield I've selected on the EFIS, but I can't see it on the EFIS itself.
Configuration is 3 x D10A, 1 x EMS10, GNS430, SL30, DSAB, EFIS modern presentation
Thanks for any help ;)
Kind regards
Thomas
You probably turned on the glideslope display on the EFIS main screen. If you have glideslope, you can't have a left info item. They just don't both fit.
You lose the info item even if the glideslope is not active.
Thomas_Schaad
Jeeh Thank you, but I prefer to have the GS up, so I have to move Air Data and scrify the digital readout of the VSI. But I guess it will only be a matter of getting used to ;) Thanks a lot and
Kind regards
Thomas
