pksgwfac6v
- Joined
- Jul 3, 2010
- Messages
- 25
I'M CONCERNED. The pitch servo (SV32) from one flight to the next was found locked in position. The previous flight it was fine; preflight for the next flight one week later reveled a locked servo (and it occurred during a pre-buy inspection too). Thinking something had jammed the elevator, I did a inspection of the canard, push-pull control rods and stick mechanism and found nothing lodged. Disconnecting the pitch servo and the elevator travel was normal. After the aforementioned inspection I applied a fair amount of steady force to the stick and the servo would not budge. I'm sure I was below the threshold of the shear pin force but what concerned me was this: in pitch a Cozy has a short control rod from the stick to the elevator; no bell crank, just a short throw of abt 18 inches. To overcome the shear pin would, I'm guessing, be a hard jabbing control input (?). However in roll, with the servo mounted on the firewall, there is a long torque tube from the stick to the fire wall with a universal mid way, then a bell crank in the wing root and another torque tube half wing span to the aileron with a universal joint in this as well. My concern is this: Trying to overcome a frozen servo in roll with a hard input to release the shear pin would result in just a wind-up of the torque tubes and possible hitting the stick stops before any real force is generated at the SV 32 arm. This I'm afraid would just be a locked up issue in roll. Catastrophic results. What would cause the servo to lock up from one flight to the next just static on the ground? These servos are numbered 2983 and 2984. 2984, the offending servo, was just replaced by Dynon. What happened? This concern is spreading through our hanger group with servos of like serial numbers.
