manifold pressure / CHT pickup
Con
I'm using the #4 primer port (Lycoming IO-320) for my manifold pressure restrictor. How do I get cylinder head temp on #4, or, alternatively, where else can I get MP?
Marc_J._Zeitlin
Tehachapi, CA 93561
CHT probes never attach to primer or injector ports, so these are orthogonal questions. Pull MP from one of the ports mentioned, or from a port you put in your intake ducting above the carb/FI servo.
Generally, Lycomings will have a CHT threaded well on the bottom of the cylinder into which you can screw the Dynon bayonet mount for the CHT probe. If you don't have a CHT port, you can use spark plug washer senders.
