GigG
It's my intention to install a FlightDEK-D180 in the Corvair powered 601XL I'm building. I know you guys don't officially support the Corvair but we both know it can be done because it has been done.
I'm needing the Builders Headstart portion of the kit with the probes and senders pretty much now. What I need is a list of what I need to order from you guys to get what I want. The outcome will look like this.
CHT on all 6 cyl.
EGT x2
Fuel Flow Sensor
Fuel Press.
Oil Temp
Oil Press.
Wiring Harness
I've got VDO fuel senders and it is my understanding that these work with the D180.
I've also got Ray Allen trim on both the elevator and aileron. Will the FlightDEK-D180 accept the position signal from these? If not what do I need to get that info into the D180.
Anything I'm not thinking about please let me know.
CHT on all 6 cyl.
EGT x2
Fuel Flow Sensor
Fuel Press.
Oil Temp
Oil Press.
Wiring Harness
