New Skyview with My Old Settings
rfazio1951
My buddy is installing a Skyview 10" Touch. I'm helping with the wiring and have a skyview in my plane. We want to set his screen up the same as mine, as far as the screen layout goes and ems limits from the sensors. I'm thinking I can copy my ems settings into his panel. I know I will have to redo the calibration on the fuel tanks, and the AOA. Will this work? I don't nessesarily want the sensor mapping, because his will be different, but I want the screen layout and gauge limits to be like mine. Can this be done? Which files should I import into his screen, all of them or certain ones?
Once you're on the same software version, export your settings. Import the .dfg file only onto his display. Then, because that will set some things that are particular to your aircraft (not calibrations, as you say), go through every setup menu item and make sure things are set the way you want them. Tail number is one thing you'll need to adjust, for example.
