OANP Server Connection Settings?
TouchTheSky
Just saw this new item in my SkyView settings, can someone explain what this is about? Either WiFi or Ethernet can be selected ...
I assume you mean OANP. That's only used for custom serial dataset connections. You don't need it unless you're trying to engineer your own software data stream.
TouchTheSky
Ah thank you, with the wrong spelling I couldn't certainly find anything here. So few more questions then:
  1. Is there a specification available?
  2. Is any traffic data included in that stream?
  3. Are there any applications already out in the market that make use of this?
I have no idea about the spec. Since it's a custom option, I assume the only data included would be what you put there. I'm not the software engineering type, so I'm probably not the best person to ask.
I saw this, too, and have no idea what it is :). Could they actually mean ONAP, not OANP?
That was originally what TouchTheSky had in his question, but it's OANP in the install manual. A misprint maybe?
