I currently have the heated pitot with controller in conjunction with Skyview.
Over the last couple of weeks I noticed the pitot heat fault light occasionally coming on then going out.
Now when switching pitot heat on, it does not work at all . (not getting any warmth and fault light staying on)
I've done some initial fault finding checks as follows:-
Fuse OK
+12.6 v input to Heater Contoller OK
GND connection good OK
White controller wire checked ie when GND = Fault on Skyview , when Open = GREEN on skyview
Blue wire measures 1.2 v ??
Orange wire measures 1.2 v ??
Black wire measures GND
I have not yet applied a direct power supply to the pitot wires to see if the pitot heats up (orange or blue +ve ??)
My initial questions are :-
1.2 v output . Is that correct?
To test for pitot heating can I apply power to orange or blue
Any other checks to help identify if fault is with heater controller or pitot probe
Kind regards
Rich
Fuse OK
Kind regards
Rich
