Corefile
- Joined
- Nov 18, 2019
- Messages
- 123
I’m not getting any percentages for my %power and I’m also not getting any numbers of HP, looking for what was missed in my configuration setting. The engine HP was set in the setup menu - any guidance on what else could cause it to be getting snow the %?
10.8.2 Specific Widget and Info Item Data Requirements
In order for the % Power and LOP/ROP status info items to calculate values, the following data must be present / conditions must be met:
• Barometric altitude (from an SV-ADAHRS-200/201) must be present.
• EMS SETUP > ENGINE INFORMATION > ENGINE TYPE must be set to Lycoming/Continental. Percent power calculations are not available for other engine types at this time.
• EMS SETUP > ENGINE INFORMATION > HORSEPOWER must be set.
• OAT sensor installed / working.
• Fuel flow sensor must be installed and configured.
• MAP sensor must be installed and configured.
These are all configured and verified, except the first bullet item, Barometric - I believe it’s present?? I get an attitude reading and when I change the altimeter setting my altitude changes. I assume that means barometric altitude is present?
