What is the proper spacing of EGT/CHT wiring with the ignition leads? I've tied up my sensors neatly using adel clamps and the lower valve cover screws now am at a loss for how to tie up my spark plug leads without following the sensor leads.....?
I drilled the holes for the EGT probes on the backside of the exhaust and put the EGT/CHT sensor wiring between the block and the intake/exhaust. I put adel clamps on the pan bolts to hold the alternator wire (and starter on the left side) and tied everything to those wires. It keeps the probe wiring inside and away from the ignition wiring.
