Screen layout problems (bugs?)
cmarbach
When I have 40-20-40, PFD, Engine,Map on once screen, the Rate of climb indicator with the value is obscured by the engine
page. Bug?
On the map, in 40% mode the letters describing the ADS-B info
get in the way of a lot of the map. Is there (should there be) a way to NOT show that info?
Carl:
Can you post a screen shot of your display showing this? Insert a USB flash drive and then push buttons 2+7 to record a screen shot.
You can turn off the weather layer, and a side effect of that is to remove the ADS-B info block, but I'm guessing you just wanted to turn off JUST the ADS-B info block.
page. Bug?
On the 40% PFD, there isn't a value on the tape itself (for lack of space), but it is shown at the top or bottom of the tape (dependent on whether you're climbing or descenting). On the tape itself, you have the needle against the VSI scale. But maybe you're seeing something else? Can you take a picture?
There isn't a way to surpress the ADS-B status at the moment, but thanks for the feedback about the clutter factor!
cmarbach
O.K. I understand the VSI and the space problem.
But you will have to admit, the 40% map is cluttered by the info.
