I have a dual-SV-10" with software 14.0, just prior to first flight doing taxi testing in my 9A. Today my second (right side) screen started something new - it boots completely and comes up with it's normal screen, stays that way about 30-40 seconds, and then reboots. The reboot starts all the way back at the original Dynon logo screen and proceeds normally to the flight display, and then the cycle repeats. Interestingly I managed to get it into setup mode and capture a diagnostic file WITHOUT it rebooting, though the process to record the diagnostic file took quite a bit longer than it normally lasted before a reboot, so I'm thinking the cause is software based.
I don't know if this has any bearing on the issue or not, but my standard startup procedure is to start the left screen only on the backup battery, start the engine, then engage the avionics master and bring up the power for both screens and the rest of the system. This might (or might not) have something to do with the issue I'm seeing. I'm just trying to avoid losing my EMS engine readouts on startup this way, I would hate to go 30 seconds waiting for bootup to find out I have no oil pressure. I also installed the next-cycle aviation and obstacle database effective next week before this problem started, in case that matters. I did the 1-2-5 reboot on the right screen, and powered them both down with avionics master and restarted, no change.
Please give me a place to send the diagnostic file so we can figure out what is happening here.
