RichDenisar
- Joined
- May 27, 2009
- Messages
- 4
For those whom may be interested, I installed sv32 servos in my lancair 320. One in the right wing, connected to the aileron bellcrank. the other behind the seat in the elevator push pull tunnel. I connected this servo directly to the push pull tube by attaching a bracket I designed to clamp on the push-pull tube and attach a pushpull tube from the servo to this bracket. In both cases I used the lowest hole on the servo arm. This allows less movement overall and adapts to the sensitivity of the lancair control system. I do not have the system fully functioning yet, however intial indications seem these settings are right on. I used 100% torque and I believe 8 or 10 on sensitivity for starters, and it is real close.
