Setting Cours Bug in multiple Sky View System
RV7Builder
Hi, we have to identical HDX isntalled. Having made our first flights some questions are actual.
Bug Knob:
Setting the Heading Bug from Pilot HDX works fine using the left knob selecting Heading and tunr the knob.
When i try this from the Co Pilot HDX, i only can select Altiude,Baro and some others, but not the heading.
Did i make any mistake in configuration ?
Thank You very much.
David
Knob use is controlled by context. If the second screen layout is not the same as the primary, the context may change. Check the BUGS Knob Function Menu entry in the Pilot's User Guide for info on what configuration changes you can make.
RV7Builder
Hi I found the solution.
You have to go to Menu, there is an item Markers. Here you can select tha available items you want to use, including warning for minimum Altitude.
