SamPrentice
- Joined
- Apr 9, 2017
- Messages
- 3
I am requesting some assistance with fault finding to a SkyView system installed into a sportstar LSA aircraft and the SV-EMS-220 engine Thermocouple unit that the EGT probes are wired to.
The system has a SV-EMS-220 Thermocouple sensor unit installed for all the engine monitoring parameters required for the sky view system.
The airframe is fitted with 4 EGT harnesses. They are of the green type insulation, unshielded and stranded core wiring. They are a complete, 1 piece, from the probe tip to the pins that go into the 25 pin D-type adapter on the Thermocouple unit.
What we were experiencing is that number 1 and no 4 EGT probes were indicating red X with no numerical indication. We managed to source 2 new harnesses of identical nature. No 4 EGT indicated correctly immediately however no 1 EGT still gave either a red X or erroneous readings of - 200 to 300 degrees when at ambient. After engine runs were done no 4 became erratic aswell.
I have swopped over harnesses to eliminate the possibility of a faulty new harness. I have swopped over with an existing working fitted harness previously installed and no difference. I have removed all the pins and fitted them physically to the Thermocouple unit sockets to eliminate mating issues and the actual connector seating correctly.
I have also cleaned both connectors with electrical cleaner but still no change.
We have managed to swop over a loaner SV-EMS-220 from a Sportstar and when we connected the unit we got 4 red X indications for the EGT temps. I am not sure if there is any configuration settings or any options that one may change in the SkyView system to set these units up.
I am reluctant to go any further with this issue before I receive some sort of guidance from Dynon. To me it looks like the actual Thermocouple unit is faulty.
