Traffic monitoring not visible on the second display
To the existing instrument panel consisting of two HDX dispays configured as a copy, we have installed the traffic monitoring system. Unfortunately it shows traffic only on one display. How to propagate it to the second display?
First thing to do is make sure you have an ethernet cable conn to both screens & the ADSB unit is also connected to them as well using the same serial port number.
skysailor
If both of the suggestions above are done try checking the Layers button on the Map Menu to ensure Traffic/WX is selected on the other screen.
chriscalandro
I don’t think the Ethernet plays in here. Make sure the serial from the ADSB rx is wired to both panels correctly. check settings, should work.
djones
Administrator
Correct, Ethernet does not have anything to do with this.
This is all serial port wiring between the adsb module and both screens.
