User Data Log field decoding
jsalak
FL
Can anyone advise me where the decoding of User Datalog fields CDI Source Port, AP Engaged, AP Roll Mode, and Transponder Status can be found? I am trying to map the number to a mode selection.
Probably this:
CDI Source Port
0-5. GPSX, NAVX, or LOCX (as in, which source have you selected to drive your HSI, on the screen?)
AP Engaged
0-7. 0=Off, 1= roll only, 2=pitch only, 3= roll+pitch, 4=yaw, 5=roll+yaw, 6=pitch+yaw, 7=pitch+roll+yaw (yaw doesn’t currently exist, but format supports it). Will read 0 all the time if no AP is installed.
AP Roll Mode
0-4. 0=Heading, 1=Track, 2=NAV, 3=GPS Steering. Always reads zero when AP roll not engaged.
Transponder Status
0-3. 0=SBY, 1= GND, 2=ON, 3=ALT
Installation Manual, Appendix E.
jsalak
FL
Thanks, I did not consider the serial data format as a place to look. Perhaps Dynon can add a note to Appendix F directing folks to Appendix E for data field definitions.
