baldcaldwell
- Joined
- May 27, 2018
- Messages
- 51
It seems that a new USER_LOG_DATA file is created in my EMS-220 each time I turn on the Battery (Master). Is there any way to create USER_LOG_DATA only when the engine is running?
If you are opening a ticket with Savvy Analysis, you'll associate a flight with the ticket, though going back to earlier flights is common to look for trends. The time of each "flight" is visible in the system.Ok that is exactly why I posted the question. I am also using Savvy and they have to sift through a ton on non engine runs to get to the actual engine runs. I'll have to figure out how to remove the non engine run logs.
Thanks!
Section 26, Appendix F, Installation Manual.So can anybody tell me why when you download the User Log Data, you also get Alert Data and Black Box Log data as well? I usually clear the data after downloading it, then save it to the cloud for future reference.
Doesn't Savvy's show/hide short flights feature take care of this? I don't see any of these unless I specifically tell it to "show" them (with the odd exception of times I may be running on shore power for a somewhat longer period of time or the like).I experienced the same annoyance...seeing lots of "flight" on Savvy and then clicking that flight to see a bunch of level colorful lines on the screen.
My work around is to export the user data files for a real flights immediately after landing and then go in the office and verify I have the data in my computer. Then just prior to the next real flight I export the user data files for the stationary ground "flights" and turn off the SV screens and then format the USB drive to scrub it clean of all of the data that produces the level colorful lines and now I have a clean USB and turn on the screens and go fly'in...repeat...
It would be a nice feature for SV to ignore all of the "flights" that have zero oil pressure and then if the screens are humming and it sees oil pressure it will only consider that user data file to be worthy of recording.
Help, I'm going blind!!!!! Can't find "show/hide short flights" on Savvy.Doesn't Savvy's show/hide short flights feature take care of this? I don't see any of these unless I specifically tell it to "show" them (with the odd exception of times I may be running on shore power for a somewhat longer period of time or the like).
Just choose “view all flight “ than “show short flights” at bottom right of screen for the times it logsHelp, I'm going blind!!!!! Can't find "show/hide short flights" on Savvy.
