VMS fuel probe compatible with Skyview?
rick789pb
I recently finished the installation of the Skyview in my Glasair III which had a VMS 1000. I"m unable to calibrate the fuel tanks! Is the VMS fuel probe system compatible with the Skyview's EMS?
Thanks,
Rick
skysailor
Rick, I have the same probe in the Glasair 2 RG I am building. You will need a converter from Princeton. This converts the capacitance output of the probe to the 0-5v that Dynon needs. Princeton is easy to work with.
skysailor
I can give you the numbers for the converter if you need them but the guy at Princeton is very good and knows your VM probe. You will have to calibrate the probe to the converter prior to calibrating the Dynon. PM me if you need more info. Happy to help. With some luck (and a lot of diligent work) I will be flying in the spring.
