B
BigFlapper
I recently had my Skyview transponder checked out and the tech. had me to change the Squitter setting to NONE from AUTO, is this the correct setting?
TRANSMIT TEST SQUITTERS: Because of limitations in the ATC radar computer systems, in US airspace the FAA require ADS-B equipped aircraft to periodically transmit their Mode A squawk code in an ADS-B squitter message. This allows the computer system to reconcile conventional radar traces with ADS-B information in a mixed surveillance environment. Because the Mode A code does not form part of the base ADS-B message set, the code is sent in a “TEST” message. Because different regulatory authorities have not agreed on the behavior of the TEST message, the installer must select the local preferred behavior. For aircraft registered in the USA, the TEST message should always be transmitted. For other airworthiness approval authorities, the preferred behavior is to apply a geographical filter so that these messages are only sent when the aircraft is visible to US radar systems. Because it has a GPS position input, the transponder already knows the geographic position of the aircraft, and therefore in this case, the recommended option setting for these messages is “AUTO”.
