Jake,
Thanks for your help.
Ok, so to be clear, the wire from my VP-X to my Stewart-Warner float-type fuel sender, should NOT be used. Instead, the Org/Blu and Org/Brn wires from the EMS should be attached to the big terminal in the center of the sender's round plate? I thought that these types of senders should have some voltage running through them in order to register 'resistance' and thereby produce measurable data to use in displaying proper fuel quantities.
Perhaps my confusion is that I'm unsure if the wires from the EMS are power, or data lines.
Would I still need to run a ground wire from each sender?
Also…as you can probably tell, I'm no electrical engineer…Your advice about the pitot heat; I am confused about "Pitot Status wire goes to a 'contact' function in the EMS & same reference applies." This wire currently is pinned at pin 9, Brn/Blu, and according to the chart titled "Example Lycoming/Continental 4-cylinder Fuel Injected (SV-EMS-220)" on page 7-13 of the Dynon install manual, is dedicated to; "Heated pitot status (contact input)".
So, as far as I can tell this wire ALREADY IS connected to a "contact function", ….it's the OTHER, UNCONNECTED end I need help with. Should it be connected to the pitot heat switch, or should I splice it into the power wire coming from the VP-X out to the pitot tube, or…????
The fog is only getting thicker... :-?
