Felllow7000
- Joined
- Jan 17, 2024
- Messages
- 5
Hi all,
Just for fun - I finally created a Head-up display working with SkyView Classic
Wanted to have my airspeed projected on the windshield for several years but was too lazy to read documentation and find out that I can get live data v. UDP unless someone from Dynon told me this at Aero Messe in Friedrichshafen, Germany (thanks!).
Now the first prototype is finally working - I setup it for IAS and fuel pressure (bar * 100). Flew couple of times with it and should say, it's quite nice to have the speed all the time in front of you, especially on final.
RPM arch (not visible on the photo) is mapped to the % of the critical AoA but needs to be re-adjusted as it shows only first two bars out of seven once the aircraft is already almost in stall.
The numbers looks a bit "blurred" - actually special glass coating is used for HUDs to avoid reflection from both surfaces of the shield - internal and external ones. For this HUD there is a special film to stick on the shield which almost remove this effect but for testing purpose I decided to not put it on. Actually in the air the numbers look better even during very sunny day with nose pointing in blue skies.
Hardware used:
- Arduino R4 WiFi Uno
- CAN Shield with D-Sub9
- Aftermarket HUD
- Couple of cables
Here is the photo. Anyone has an experience with such stuff?..
Regards, Fellow7000
Hardware used:
- Aftermarket HUD
- Couple of cables
Regards, Fellow7000
